i change brake pads now all brake lights are on
hello friends ,i just change the brake pads it was eaasy ,but when i started the engine the brake lights are on,the stability control ,the pcs & the abs are on too & the information shows check pcs ,check vsc ,check ecb , i umplog the battery for a minute but didnt help if some one can help me please i will apreciate any help ,thanks
ah thats easy.. i come across this everytime i do my brakes.
if it says anything related to a hydraulic problem then
just reset the codes in the abs/trc/vsc..... and voila everything works back...
if no hydraulic codes... then u need to reporgram the whole system,, 4 steps only..
1/ go to abs/trc/vsc , ecb utility and reprogram (1.ecb, 2.abs, 3.vsc and 4.zero point calibration).....
all that should be done using toyota techstream or toyota intelligent tester...
Thanks for the replies friends, the thing was that I did press the brakes when I was changing the brakes. It was my error by doing so. I took it to a friends shop to reset it. It looked like a Christmas tree with all those lights on luckily its Christmas. LOL... My friend at the shop did state that I should of taken off the battery when I was changing the brake pads. I would like to thank you all for all your help once again you guys are GREAT!!!![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
PeteV
07-07-10 10:11 AM
