97,000 Miles: Preventive ideas
You might need to provide the model you have to have this question answered. Although many of the main components of each car, V6, V8, AWD, and Hybrid are the same, they still will have different components which may need to be addressed at the 100K point.
Also the assumption would be that you have been getting maintenance at the suggested intervals up to this point.
I just did my 90k service and I have a V8
I changed out the water pump, spark plugs, serpentine belt, timing belt, timing belt tensioners, air filter, cabin filter, changed out the diff oil, flushed coolant and also the brake fluids.
Suspension stuff depends on the car - i only changed my struts once they were gone 127k. Before that - there's no need.
On top of timing belt, you can do what i did and get other misc stuff that people overlook when doing a tuneup. Like spark plugs, fuel filter, bushings are cheap - you can opt for those, along with end links. You can go as far as doing the spark plug wires [more pricey], do other stuff like air filter.
This is all assuming your car is stock.
Otherwise get some coilovers - cheaper than struts
Btw, i get my stuff from www.rockauto.com - cheapest anywhere for good quality stuff; they don't sell junk.
Sorry. 1006 GS 300 AWD seperate mounted snows and summer tires.
Done already: TPMS Rotors/Pads four wheel alignment Wiper blades Air filter cabin filter Brakeflush Water Pump S Belt Transmission service.
Is there seperate differentials front/rear? Anything else?
I checked Sewell before asking my friend and the kit they are selling online is not really the true 90k miles kit...
Pogo
12-19-06 07:57 PM
