Help: VSC and Check light on
Check your gas cap. Mine came on shortly after I bought it and the gas cap was bad. Check tightness first. 2 - 3 clicks.
There are plenty of post on it. Just search through the stickies.
i had it few days back and took it to check the code..they came up with report says that i need to change the eveaporation box on the tank.. i asked him to clear the code and i changed the gas cap.. now no more lights on
..cheap fix
Well ive had this lil problem since oct, changed an o2 sensor was fine for almost 2 weeks, then came back on took it back to mechanic they changed it again loght came back. Went and got some cat cleaner cleared the code, same thing about a week it would come back on. So today I finally said ef it, dropped it off at dealer to see what they say is the real problem. My error code kept coming up P0420 so its not the gas cap, thats a different code, on the lighter side I get to drive 2012 RX350 till their done
Well dealer called back not the cats, but there is a leak on the exhaust pipe, covered under warranty so theyll be replacing it, and did all 3 recalls so I get cruise with the rx till theyre done
