Help 10mm wheel spacers???
My question is if i put 10 mm spacers on my gs350 would i need to change the studs or can my wheel still bolt on safely without the longer studs????? Soory for the newbie question
by the way the wheel is a 19 x 8 with +35 offset
mikalbraxton (03-16-24)
@ passnu2:
to clear the front brakes with the wheel size/offset, would 10mm work or can it be less? only myfronts are this size and hence the headache so trying to figure out what would works best, didnt really want to have to mess with studs being changed
15 mm is the smallest bolt on you can get. But what is the size of your rear rim. You may need something for the rear so the fronts are out more then your rears.
You can try with your rims and see if you can get away with a 3mm. I was able to just barely get away with this but it was the design of the spokes on the rims. If this will work then I would feel ok with not changing the studs but my guess is you will need 5mm.
