2006 gs300..help plse
plse someone help, i accidently tap a test light to the yellow ignition wire under the glovebox and it shorted, now my car wont start unless i put it in neutral and i cant turn it off unless i pull a fuse....anybody got any idea wht i shorted out? dont want to take it to the stealership
its the yellow wire behind the glovebox, yea i chked all the fuse n relay....was using a test light w/ ignition on and tapped into that wire n it sparked...then all the instrumental gauge lights cut off and on again....and cant turn off car
I dont think its a fuse because the OP stated they can start the car in N but not in P. So the push start is getting power or it wouldn't work in N.
you have fuses on both kick panels up front, under your hood, and in your trunk...cant hurt to just double check as that's a cheap easy fix.
took it to the dealer, they saying its the ecu, crap so iuno if its really ecu or neutral safety switch....yea all the light is right and radio and everything works
they gave me a part #: 8967030010, do you happen to have the location of the part? or how to replace it?
thanks alot,...i have a question....so my lil bro told them to go ahead and order the part and do the job, they quoted the part $1,042.80, but we can get it on sewellpart.com for like $636.11, so i called the dealer back they said the cant cancel it, and they gonna keep the car until its done. can they do that.
