DIY Battery Replacement - OEM size replacement
Old 06-02-13, 08:21 AM
LexToy3
LexToy3's Avatar
I have usually replaced mine with sealed ones like optima, any reason that you wouldn't choose one of them?
Old 06-02-13, 11:15 AM
LexG
LexG's Avatar
I would go with the OEM battery. I am still on my original battery on my 06 GS300, going on 8 years and I live in the Las Vegas desert. The dealer price is $140 installed, which I think is not bad based on my experience with car batteries. I had an Optima in my previous vehicle that barely lasted 4 years and cost more. I believe the OEM battery is an Interstate, according to the dealership service department. I put an Interstate in my 96 Impala that I drive, maybe once a month, and it starts right up every time.
Old 10-28-13, 12:41 PM
fastnoypi
fastnoypi's Avatar
Id go with any battery with 700ccA or greater , Group size 24F
The biggest supplier of auto batteries is Johnson Controls, next largest is Deka, then they are relabeled to any house brand.
The Everstart Maxx at Walmart is probably the best deal currently, includes a 3 year free replacement and additional pro-rating 2 years after. Look out for the warranty per reseller distributor, slowly they are only offering 3 year free replacement.
as another fyi, if you have a Sears diehard and having problems, they charge $20 for diagnostic if its in the car, free if you bring only the battery.
Old 10-28-13, 05:14 PM
MelYW
MelYW's Avatar
Is this the same deal as Costco?? I think Johnson makes their batteries. I think for 24F it is about $85. 3 years free replacement. 100 month limited warranty (prorates after 36 mo). I have my original battery and want to know if the Cost fits and is a decent deal.
Old 01-04-14, 03:31 PM
slatronica
slatronica's Avatar
I just replaced the battery in my 2007 IS250 but am having a lot of trouble getting that bracket on the front tight again. Any tips?
Old 11-17-17, 10:35 PM
LexVoitek
LexVoitek's Avatar
Exclamation Lexus OEM Battery 11 years old! Swapping How-to Guide
My original 2006 Lexus GS300 car battery is still working and it's 11 years old. It only pulls 258 CCA (cold cranking amps), so I finally did the research and swapped it. It must be Christmas because I'm hooking you guys up with my complete how-to guide, how to test your cold cranking amps, how to trickle charge your batteries, and what the original Panasonic 80D26R Lexus GS car battery goes for !
ENJOY!!!
This is the battery size spreadsheet I made for my 06 Lexus GS300. I went with group size 34, but still had to mod it as seen in my how-to video.
When I was bored once I looked up the cost of a replacement car battery for the GS and my jaw dropped. But, my GS battery lasted 11 years!
The following 2 users liked this post by LexVoitek:
2eXceL (02-06-20), bob256k (08-02-19)
Old 11-21-17, 08:33 AM
703's Avatar
Replaced with a 90AH battery.
Old 06-08-18, 10:53 PM
ecast0603
ecast0603's Avatar
Unhappy
hi guys! i just replaced the battery on my gs 300 but th car won't even start. The radio and the dash board lights won't even come on. Can anyone tell me what im doing wrong?
Old 06-09-18, 11:18 AM
rw3
rw3's Avatar
This is the battery recommended to me by a Lexus Certified Master Technician (think LFA) as well as an Acura/Honda Certified Master Technician (think original NSX).
https://www.pepboys.com/product/deta...03.5L%2520DOHC
Old 06-09-18, 08:09 PM
tghw
tghw's Avatar
You link goes to the Pep Boys home page.
Old 06-10-18, 09:15 AM
rw3
rw3's Avatar
Lets try this link: https://www.pepboys.com/product/details/844459/
If that doesn't work, simply search for "Bosch 24F AGM"
EDIT: Link doesn't work when linking from ClubLexus...SMH.
Simply use the search term above. 710 CCA at 0 degrees, 810 at 32 degrees.
Old 06-10-18, 10:36 AM
tghw
tghw's Avatar
Thumbs up
That link works.
Old 06-11-18, 01:56 PM
arnieosp
arnieosp's Avatar
Possible reasons:
1. The battery is DOA.
2. While connecting the terminals, you accidentally switched polarity and fried master fuse.
mikeho
05-22-23 02:29 PM
wpb
01-22-18 07:40 PM
Bonapartis
Performance & Maintenance
12
08-09-16 11:37 PM
Rustito
01-13-13 08:59 AM
Kostyan
05-04-10 10:43 PM
Quick Reply: DIY Battery Replacement - OEM size replacement
