Hid bulb flickering
Old 01-04-12, 10:41 PM
GS2100
GS2100's Avatar
Default Hid bulb flickering
Anyone know what could be the problem driver side Hid light bulb flickers sometimes then turns off and when I notice it I usually turn the headlight lever off then on and then both headlights are working again.
Old 01-05-12, 11:17 AM
alwayzspeedin
alwayzspeedin's Avatar
mines do the same thing but on the passanger side....i was told the ballast might be bad , i just keep telling myself NO!!!! cause i'm to cheap to go buy another one. so i do what you do turn it off and back on
Old 01-05-12, 12:17 PM
energie8
energie8's Avatar
Mine was doing that then it totally died within days out so I replaced both of them and now it's fine.
Old 01-05-12, 12:57 PM
IXI187IXI
IXI187IXI's Avatar
not another one of these threads again
swap your bulbs to the opposite side to see if the problem still happens. that will help you determine if its the bulb or ballast.
Old 01-06-12, 12:37 PM
dchan419
dchan419's Avatar
I dealt with this same problem for 5+ months. I was away at school so i didn't get around to changing them (read: too lazy or too drunk).(don't drink and drive!)
I turned them off and then back on whenever i drove and after awhile i got use to it. They tell you the ballast may be going bad but i would def change the bulbs first. My problem started a week after i bought some bulbs from some ebay store that was recommended to me on here, but i had a bit of a problem with the warranty... but that's neither here nor there.
I bought a pair of bulbs from amazon (toshibas) for 50 bucks this past summer and boom, problem solved. You should try the bulbs first, at 50 some odd dollars a pair, its worth trying.
Old 01-06-12, 01:04 PM
FH212
FH212's Avatar
When that was happening on my IS250 it turned out to be the ballast.
Old 01-08-12, 07:41 PM
GS2100
GS2100's Avatar
problem seems fixed I switched the bulbs like XI187IXI suggested in an old thread several years ago
so far so good I hope I just had a loose connection.
Thanks.
chinewalk
09-04-13 05:14 PM
apdimitri
05-12-12 02:11 AM
Swishh
07-13-11 12:00 AM
cestjoel
05-29-11 06:45 PM
freshrice
07-08-10 05:02 PM
Quick Reply: Hid bulb flickering
