^^^^ No this sounds a lot more serious then that, check brake fluid ASAP!!!!!!!!!!!!!! Infiniti is also known to throw this lights when pad is low which uses more brake fluid in the lines causes brake fluid to be lower then usual.
I've been busy replacing my breaks, but while I was doing it I over torqued a bolt causing it to brake... I'm really tired now and need to take a brake.
Preventing "break" threads in car forums one post at a time.
