Brake fluid change
Brake fluid change
Time to change out my brake fluid.
I am thinking of using a master cyl. pressure set up I have that allows you to pressure the fluid through it and then just bleed it at the calipers.
I have done this on my Ford Lightning quite often as I use it at the track and keep fresh fluid in the system.
The truck has ABS as well so I am thinking it should work.
Anyone done the fluid exchange on their GS350?
Any tips would be appreciated.
