Slammed GS450h - 20" Vossen CV2's
#32
I think you may have misunderstood what I was trying to state: With the vossen staggered setup (mind you mine was more aggressive offset) I had wear issues in the inner tires too. I also stated that in order to make my set up work (again my stance was lower than OP) I had to shave the fenders front and back and to correct wear issues would have to install a camber kit. I do think the added weight of the Batteries creates more negative camber but the fix is still the same if you want to run lowered and staggered.
lottaloot
09-15-12 09:32 AM
