How do I change side bulb.
The little bulb inside the headlight, on the side, one that illuminates yellow reflector went out. Do I have to remove the headlight to get to it? How hard is it to remove the headlight if I do have to do it?
Thanks
Thanks
Actually....... its a same big plastic thing that you used to take out the parking lights in the DRL. Its on the side on top, nothing to do with the housing. K lets imagine the passenger headlight is shinning at me, on the right is the big plastic thingy for the 194 DRL led u installed, in the middle is the hid and on the left side hiding near where you put in a screw driver to adjust lights its right there. Im sorry its late, if you don't understand what I mean ill snap a quick pic for you tommorow.
No need for pic. Sounds easy enough. Thank you very much. Will get this fixed saturday!!
Dave
