AFS=Jitter Headlamps Over Bumps
Yes i do, that happend to me when i hit a huge bump and the projector was loose. I had it replaced under warranty. A good way to check is, come up to the headlight n hammer fist bang it on top of the headlight see if it moves around, if it does you need to replace the headlight.
like he mentioned, try to bang on the headlight and see if it is loose. i hit a deep pothole, and mine is definitely broken (it was pointing up, illuminating all road signs). i have to go to the dealer and hopefully try to get this fixed this under warranty. i noticed the little bounce before also, but the difference is pretty clear when it's actually broken.
Guys, I'm not talking about a broken headlight where you put some force on the housing and the light shake. Or the beam is completely aims high or low.
This is a little vibration in the beam when driving on the bumpy roads. Without any car in front of you, you'll won't be able to tell if it's bouncing up and down. But if you can see your light hitting another car's bumper, the cut off of the beam vibrate up and down on bumpy roads.
Mine def show a bounce when going over rough roads and speed bumps..the light itself is clearly moving...any clarification if this is indeed normal or can be replaced under warrnty...I have CPO
