AFS=Jitter Headlamps Over Bumps
When I first drove the car out of the lot , I notice my light would bounce up and down over bumps. My first thought was oh *****, I have a lose headlamps. The first thing I did when I got home is google the problem and it seems to be normal on the GS because of the AFS.
However, even with the AFS turned off, the bounce is still there. What gives? The RX also have AFS and the headlamps is solid.
Yes i do, that happend to me when i hit a huge bump and the projector was loose. I had it replaced under warranty. A good way to check is, come up to the headlight n hammer fist bang it on top of the headlight see if it moves around, if it does you need to replace the headlight.
Well this thread seem to suggest that it's normal.
https://www.clublexus.com/forums/gs-...ver-bumps.html
It's not a hard shake or anything, just the cut off beam is moving up and down. I wish more people would input in this thread.....If there's a mechanical reason for this and is normal then okay. If this is not, then Lexus should fix it.
