Need your opinion on these wheels
Goal: As close to stock as possible on 19" lowered with NF210. I saw the wheels below from one of the vendors, and need your input. Will the offset +44 cause any issue? I think the hub bore size on these wheels are 73.1mm, can I make them work on 07 GS305 AWD (60.1 mm)? Will they look good on 3GS? Thanks.
https://www.clublexus.com/forums/whe...5-w-tires.html
20" and there are many rim companies out there that make beautiful wheels. vossen is just one of them check out some forgiatto's or even better cor for forged aluminum,3 pc or even super concave wheel designs! bad ***. but deffinately stick to 20's
Thanks for the info. I will search around. Since this is my daily car with 2 small kids (4&6) at the back, 19 is as far as I can go.
my wheels are the same diameter and width with the same size tires. my offset is a tiny bit more aggressive at +38 and have no issues whatsoever. maybe you can find hub adapters to correct the bore size.
as for the design of the rims, i don't think they're terrible but i agree that it may not look good on our cars. BUT if you like them then that's all that matters.
