Guess who's got LED DRL's?
#31
They're actually part of my car club, but thanks glad you like the design! ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Wait, if it's just one intensity then that doesn't mean you have functional high beams.
That just means you have a brighter than normal DRL..which is the same as the V-LEDS kit. That was misleading, I think there is no way to retain HIGH BEAM FUNCTION once you go LED's...
#34
Sounds like you keep the high beam function it just happens to be the same brightness as the DRL function which for most of us means that you lose the high beam function.
Too bad... if it did the dim (DRL) and the bright (Highbeam) I would be ordering a pair... if it is just a constant "mid range" brightness then for me it is no sale and is probably borderline illegal where I live... If nothing else I would expect to get flashed by every other approaching driver at night.
