over spec tires
Would there be any problems besides possible rubbing if I were to run 245/35/20 and 285/30/20? I don't think I'm going to put springs on my car because all the shops around here want close to $500 just for the install. If anything I would do rca's on the front. I'm awd and noticed some others are running 275/30/20 in the rear but the 285/30/20 is almost a perfect match for the front. Thanks for any input.
I'm looking for the same info. The specs match between the 245/35/20 and 285/30/20 and the 275/30/20 is just slightly smaller in diameter. It's also almost and inch less in width. I'm putting on a set of Megan LP coilovers and want to make sure I don't need any fender mods.
Whitena, what did you do to prevent from rubbing? mine rub a lot. I have the same 245/35/20 and 285/30/20. I have very high offset. What did you use for the lowering?
im running 245/35/20 up front stock suspension only rub on hard turns. 275/30/20 at the rear rubs if I have people in the back and hit a bump, no mods to fenders
