p0500 HELP!!!
I ended up getting the usual P0500 vsc trac check engine combo on my dash. I have a 2006 GS430 with 38000 miles. I ended up taking the vehicle to Lexus after replacing speed sensors to make sure they wouldnt tell me it was that. Replaced both just in case. The ended up replacing ECM after finding sensors were good & wires had no shorts. After replacing ECM the said code came back up p0500. It won't throw the code untill I hit 2500 rpm's. I asked them about the trans assembly they said the ECM & engine & trans should show the same reading. The Ecm & engine are with the trans reading different & they dont know why. I asked about replacement they said if they did they'd still get the same reading...Does anyone have any answers or experience with this? It would be greatly appreciated it...I MISS MY GS...Thanks
omg.... i remember I had this similar problem that I solved by myself. when it comes up I will edit this post. Good luck however!
Ohh, i remember now, mine's was a gas cap issue. Have you tried replacing that? If not give it a go, and reset your battery. See if that fixes it...
I disconnected the battery to reset it...tripped code after I hit 2500 rpms I dont know if that means anything. Wouldnt it set an additonal code if it were the gas cap. Did yours set any? If so what code.
Last Modified: 3-1-2012 6.4 C From: 200501
Model Year: 2006 Model: GS300 Doc ID: RM000000W8E000X
Title: A960E AUTOMATIC TRANSMISSION: ELECTRONIC CONTROLLED AUTOMATIC TRANSMISSION SYSTEM: P0500: Vehicle Speed Sensor "A" (2006 GS300)
DTC
P0500
DESCRIPTION
The speed sensor SP2 detects the rotation speed of the transmission output shaft and sends signals to the ECM. The ECM determines the vehicle speed based on these signals. An AC voltage is generated in the speed sensor SP2 coil as the parking gear mounted on the rear planetary gear assembly rotates, and this voltage is sent to the ECM. The parking gear on the rear planetary gear is used as the timing rotor for this sensor.
The gear shift point and lock-up timing are controlled by the ECM based on the signals from this vehicle speed sensor and the throttle position sensor signal.
![](https://techinfo.toyota.com/t3Portal/document/rm/RM1167U/images/C106174E02.png)
DTC No.
DTC Detection Condition
Trouble Area
P0500
No speed sensor signal to ECM under following conditions: (1-trip detection logic)
(a) Park/neutral position switch is OFF
(b) Vehicle is being driven
•Open or short in speed sensor (SP2) circuit
•Speed sensor (SP2)
•Automatic transmission assembly
•ECM
MONITOR DESCRIPTION
The output speed sensor SP2 monitors the output shaft speed. The ECM controls the gearshift point and the lock up timing based on the signals from the output speed sensor SP2 and throttle position sensor.
If the ECM detects no signal from the output shaft speed sensor SP2 even while the vehicle is moving, it will conclude that is a malfunction of the output speed sensor SP2. The ECM will illuminate the MIL and set a DTC.
MONITOR STRATEGY
Related DTCs
P0500: Vehicle speed sensor circuit
Required Sensors/Components (Main)
Required Sensors/Components (Related)
Throttle position sensor, PNP switch, ECT sensor, Crankshaft position sensor, IAT sensor
Frequency of Operation
Continuous
Duration
2 seconds: IAT is -10°C (14°F) or more
8 seconds: IAT is less than -10°C (14°F)
MIL Operation
Immediately
Sequence of Operation
None
TYPICAL ENABLING CONDITIONS
Monitor will run whenever these DTCs are not present
None
Battery voltage
8 V or more
Engine RPM
2,160 rpm or more (varies with throttle position)
Either of following conditions A or B is met
Condition A:
Time after PNP switch ON to OFF
10 seconds or more
ECT sensor
ECT is 20°C (68°F) or more and ECT sensor does not malfunction (P0115 or P0116)
Condition B:
30 seconds or more
ECT sensor
ECT is less than 20° (68°F) or ECT sensor malfunctions (P0115 or P0116)
DTC
P0500
DESCRIPTION
DTC No.
Trouble Area
P0500
•Speed sensor (SP2)
•ECM
MONITOR DESCRIPTION
MONITOR STRATEGY
Related DTCs
Continuous
Duration
MIL Operation
Immediately
None
None
Battery voltage
8 V or more
Engine RPM
Condition A:
10 seconds or more
ECT sensor
Condition B:
30 seconds or more
ECT sensor
I didn't check for any codes, i went straight ot lexus and they replaced the gas cap so i'm sorry I couldn't help, but if it WAS the gas cap, and the gas cap was replaced, your car should reset the CEL after a few drives. So in your case I apologize, but I was wrong. I might look up at the diagram up above. Have you had lexus check with a voltmeter to see if the line is accidentally disconnected from the speed sensor to the ECU or wherever the last line ends? Worth a try to make sure the wiring harness is all good.
Thanks for the replys I'm starting to think myself its the transmission itself...if the rear planetary gear which acts as rotor is wore or damaged I think it wouldn't send a signal...or a different one...Lexus tells me the dvr or whoever is suppose to call California after which point they'd get back at him n tell them how to proceed...could be full of it but who knows...I'll defintely show them the above tech sheet...hopefully it works...ill let u know thanks
I am shocked to hear a problem such as this on a low mileage 430.
Good luck and please keep us updated.
Well they said its not the above tech sheet...The tech said he called California...doesnt like to because he likes to figure things out hisself but did so. He said California told him to check the wiring on the vehicle speed sensor that has 3...1 of those is suppose to be bad & giving out improper readings...they're suppose to call me back after they pulled it in...havent heard anything since earlier I will update when I hear the news...any new ideas are welcomed...thanks
Yeah besides this issue that cause the lights to pop on on dash...the car runs & drives excellent...looks like a low mile Lexus to I really hope Mcgrath hurries up in it...havent got to enjoy it yet...will post pics when.....whenever I get it back home.
we figured that out from the beginning already GS4
The techs at lexus have tried a lot of things to fix the issue, but no avail.
john, let me know how it goes! As I said, I made the call on the wiring harness on the trans so hopefully they'll just stop checking and replace it to see if that remidies the problem.
P.S. I've been on my 06' GS430 for 2-3 years now, my only super serious problem was the rear roof creaking (in which lexus made me PAY for it =\ ). So there shouldn't be any issues with 3GS's, especially low mileage, i say this car just stumped upon a freak accident
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
