HELP - How do I turn on fogs without turning on the headlights
I tried searching for it but I couldnt find the thread. I know its possible because I've seen 3GS's in my area with it done. Can someone please tell me how to rewire so i can run my fog lights without turning on my headlights. I'd like to run my DRL's and my Fogs.
Have a 2010 and the fogs only work when Low Beam is activated. When in high beam mode thje fog lights automatically turn off. Come back to low beam and fogs lights come back on automatically. They will not work in fog light mode only, as wired by the factory.
I haven't done it yet, but I'm assuming all you have to do is find the power wire to DRL and splice the power wire of the fogs to the DRL and it should turn on when only the DRL is on...
But that's just me guessing.. if anyone can confirm ...
i can confirm you will burn the wires on your system like that outkast, that's way too much of a load.
What you do is buy a HID Relay kit, and the DRL's will activate and act as a "turn-on" switch.
http://www.ebay.com/itm/HID-Kit-Digi...814257&vxp=mtr
Hope that helps. You can also connect this onto a flip switch and wire it into your cabin so you have the availability of turning it on whenever you like. Just make sure it's off when your real fog's power is activated.
That could be done, unless you're using HID's, in which case you have to use what i posted. Still I reccomend using the HID Relay thing, better safe than sorry.
I haven't but that's what i've seen people do in my area. I dont like the whole rewiring my foglights ordeal, I have HID in my high's area so it's enough for me.
