Can Someone Help Please!!!
I'm trying to find out how to take the sub in my car out does the cover clip on like the front ones, if so do I need to just pry cover off to see it and take the back seats out. Thanks in advance.
On my car, you have to remove the rear seat (upper and lower), then remove the side panels, then you will have access to lift up the rear package tray. The sub is held in by 4 10mm bolts. For the rear seats, the bottom pulls up from the front first then slides out. And the back is held in place by 6 14mm bolts, 1 behind the left and right headrest and 4 on the bottom. I am not sure if the hybrid models are the same. GL
btw. Hybrid model should be the same as other 3GS'
marcuse
02-04-09 11:53 AM
