Need help and some suggestions
I found out that my Recirculation in my 3GS is not working so i took it to Lexus and they told me that they would have to replace my air box and my whole glove box and they told me that it was the recirculation door that was not operating properly and also that this wouldn't be covered under warranty so they gave me a quote of 2500 + 5 hours of labor. I need suggestions on how i could fix this problem without taking it to the dealership i also looked for the part and this is what i think controls the recirculation door THE SERVO SUB-ASSY, DAMPER i wanted to know if this is easy to replace.
Thank you,
1SloGS
Thank you,
1SloGS
They said it was forced open or something and I haven't done anything to it so I was like ok ill just look up the part my self and try to do it but I needed suggestions on how to go about it
This is typically done when someone tries to replace the cabin air filter on their own without setting the A/C system to recalculate first. and then they force the little door open.
Unless it was the dealer who replaced the cabin air filter you are going to look long and hard to find any dealer who is going to do this work under warranty.
This is typically done when someone tries to replace the cabin air filter on there own without setting the A/C system to recalculate first. and then they force the little door open.
There are some threads on this forum from people who have managed to open up the AC box, collect the broken plastic bits, and epoxy them back together, but as I understand it you need to take most of the dash apart to get to it... If you were nervous about a DIY cabin air filter project... a DIY recirculate door activator expoxy fix is probably off of the table.
Here is the link
https://www.clublexus.com/forums/gs-...glove-box.html
I did my own. Hardest part is cleaning all of the junk out of the glove box, 5 minute project tops... But skip that one critical "first" step and you are looking at a $1000-$1200 repair bill... IMO there should be a big yellow warning sticker on the door at the back of the glove box.
Here is the link
Here is the link
rrr
12-04-16 01:06 AM
