it means tire pressure is significantly lower than what it was set at. Check your tires to see if you have a flat tire.
I just got mine plugged last week after the same message popped up.
Low air in one or more of your tires it doesn't tell you which one you are just going to have to check all tires and inflate of needed and the light will go away.
