Need positive ID.
Need positive ID.
Fellows,
This is a very series issue and I need all the help I can get.
I believes this is the OEM spec nut for a 06 GS300 AWD:
But what I need to ID is this one:
Apologized for the huge images, I just wanted to show all the details.
BTW, they both have the same thread.
Any idea/info is greatly appreciated. Thanks
second nut is off a civic you can tell because of the acorn and the plastic ring. they will work on any lexus and infact its what i usually use with aftermarket wheels since there low profile and very easy to get a hold of cheap
they will work as a replacement to a factory lug nut in a pinch
I don't know much about civic. Any more info on the year/model of civic you are talking about?
Or they all use the same style nut?
its pretty much any honda/acura with hubcaps hence the plastic ring its what holds it on the car! no aftermarket lug nuts have that plastic ring unless they are a OE replacement for a honda/acura
pitch is the same between honda/acura/toyota/lexus
