2007 gs350 power steering failed. Need help!
Old 04-30-12, 03:19 AM
ynyuke
ynyuke's Avatar
Default 2007 gs350 power steering failed. Need help!
I have a Lexus 2007 gs350 and my power steering isnt working. Any ideas what exactly it may be? I was thinking the power steering rack needs to be replaced or the power steering module may have failed perhaps? It would sometimes work on a start for a few seconds and thats it.
Any ideas or suggestions anyone?
Old 04-30-12, 07:10 AM
bigblack06
bigblack06's Avatar
How many miles? guessing its hard to turn steering wheel, are you out of warranty?
Old 04-30-12, 08:32 AM
IXI187IXI
IXI187IXI's Avatar
happened to me. dealer determined it was the rack that was bad.
did you have the rack replaced under the recall? there was a recall a few years ago, if you havent had it done, now would be good time
Old 04-30-12, 10:05 AM
ynyuke
ynyuke's Avatar
It's got around 55k on it and no I haven't done a recall on the steering rack. I called them before and they told me there was no recall on that except for some valve spring. Was there a recall on the steering rack ?
Old 04-30-12, 11:10 AM
IXI187IXI
IXI187IXI's Avatar
heres the info for the rack, it may help
SSC9LC JAN 09 Campaign - EPS Steering Gear Replacement
SSC6LE JUL 06 Campaign - Electric Power Steering (EPS) Replacement
Old 04-30-12, 02:00 PM
2008GSh
2008GSh's Avatar
Do you have active links... Without any detail those aren't much help
Old 05-01-12, 08:18 AM
thinksimpl
thinksimpl's Avatar
I had the same problem--the steering ECU went bad.
Old 05-01-12, 09:36 AM
IXI187IXI
IXI187IXI's Avatar
heres the only one i could find on here
SSC6LE
you can pm TWong350 and he can give you an TSB you want
Old 05-01-12, 06:07 PM
chuckGS350
chuckGS350's Avatar
If enough people complain with NTHS, Lexus may have a recall on their EPS.
The latest TSB is
L-SB-0015-11
March 23, 2011
Notchy Steering Feel at Highway Speeds (4WD)
Introduction
Some Lexus vehicles may exhibit an intermittent non-binding notchy steering feeling and/or the steering wheel does not smoothly self-center when driving at highway speeds. This condition may occur when changing lanes or when coming out of long sweeping turns at highway speeds. Please use the following repair procedure to address this condition.
I look at the TSB. The repair is the replacement of the Power Steering Gear assembly.
The TSB applies to all 2006 GS300 AWD, 2007-2011 GS350 AWD with last 5 ditigts VIN# below 28532.
Old 05-02-12, 03:05 AM
ynyuke
ynyuke's Avatar
I called two Lexus dealers and both saidthere was no recall for my car after they looked up the vin of my car. I am going to take it in to them and have it diagnosed.
Old 05-02-12, 07:24 AM
energie8
energie8's Avatar
That happened to me last winter, it cost me 3000$ for everything. =/
Old 05-02-12, 07:56 AM
IXI187IXI
IXI187IXI's Avatar
i know to replace the rack out of pocket is around $2100. Thats what i was quoted from my dealer. Luckily i still had my 3rd party extended warranty and it only cost me $100
Old 05-02-12, 08:00 AM
ddixon03
ddixon03's Avatar
Default power steering rack problem
I see a lot of posts on a power steering rack problem. I am new to this forum. Last week I got in my car and it simply would not turn. The P/S light came on. I took it to the dealer and they said that my power steering rack needs to be replaced. They said that my car was only eligible for one recall related to power steering and I had that done 3 years ago. My VIN does not come up for the other recall. There is definitely a problem regardless of what my VIN number is.
I bought this car because of the Lexus brand. I did not expect repairs that cost over $2500 when I haven't even finished payments. It is unusable right now. and only has 80,000 miles on it. If you have encountered this problem, what were you able to do about it and what else can I expect to go wrong on my GS300?
Thanks,
ddixon03
Old 05-03-12, 07:29 PM
ynyuke
ynyuke's Avatar
Dealer determined my rack was bad. Two options that I have and would like some suggestions.
Option1: Buy a used rack for $500 ish from auto parts place with 2-3 months warranty.
Option 2: Buy a remanufactured one for $720 with lifetime warranty.
Not sure which one I want to go with. Do these steering racks go out anytime? I just wouldn't want to buy a used one not knowing how many miles are on it and see it fail again and pay out of the pocket for another one. Suggestions would help.
Old 05-03-12, 08:49 PM
Mikeyy
Mikeyy's Avatar
I would suggest not to buy a used ps rack as it is an electronic component not the old style hydraulic racks. Really hard to test those units to verify if it is working properly.
Since I see you only have 55,000 miles, I would actually call the lexus customer helpline and see if they can offer any assistance in repair since youre only out of warranty by 5000 miles
Quick Reply: 2007 gs350 power steering failed. Need help!
