3GS Resonator Removal
Old 05-09-12, 11:05 AM
jayajello
jayajello's Avatar
Default 3GS Resonator Removal
I'm sure there is a thread like this out there, but i honestly couldnt find it
BUT!
I want to get my resonators removed soon. What exactly is needed to be done? How long does it usually take? What problems can i run into without resonators?
any information about this would be great
Thanks.
Old 05-09-12, 11:38 AM
M K S
M K S's Avatar
Are you on a full stock exhaust, or do you have an aftermarket cat-back?
Removing your resonator is a very simple job and shouldn't take an exhaust shop more than an hour. There isn't much too it, simply remove the OEM unit and replace it with the same diameter strait pipe. I had mine removed about a year ago and have had no ill effects since. No check engine lights, etc. I wouldn't worry too much about running into any problems. If you removed your cats, that's different and you'd have to take a few additional steps w/ the o2's.
Old 05-09-12, 12:04 PM
jayajello
jayajello's Avatar
My exhaust is fully stock, I'm going to talk to my mechanic about it. Thanks
Old 05-09-12, 12:07 PM
M K S
M K S's Avatar
NP. Any exhaust shop that you trust should be able to do it fairly cheap. Good luck.
Sorry I don't have any sound clips.
Old 05-09-12, 02:07 PM
jayajello
jayajello's Avatar
Thank you very much, I'll post a sound clip when it's all done
Old 05-10-12, 10:02 AM
little2576
little2576's Avatar
question whats the benefits of removing the resonators ?
Old 05-10-12, 11:23 AM
XxGoKoUxX
XxGoKoUxX's Avatar
A little bit of a meaner sound
djkidd
01-15-15 05:26 AM
Vadim540i
SC- 1st Gen (1992-2000)
13
09-24-10 10:43 PM
jcat_350
NELOC
10-16-08 11:37 AM
MrlexusSC
Performance & Maintenance
11-21-05 09:29 PM
ChrisK
03-30-03 03:49 PM
Quick Reply: 3GS Resonator Removal
