just picked up an 07 GS350 this week
Got under the hood today and unbuttoned all the plastic crap to see what I had. Couple of questions and I did search but did not see anything on where the power steering reservoir is. I did learn the tranny fluid cant be changed unless going to a Lexus dealership to hook up to a special machine. Is Power steering fluid the same? I am not comfortable running fluid forever in a car. Last question I could not find a search hit on is there a diagram showing o2 sensor locations? I only could see one from the top on the driver side closest to firewall. Thanks in advance for any comments to help me out.
ruthiej: The oxygen sensors are located near the exhaust manifold under the car. One is located between the catalytic converter and manifold. The other is after the catalytic converter.
I got that off Ask.com
Thanks to all that have responded. Is there a way to do a drain and fill on the tranny? I saw in the owners manual a drain and fill with less that 2 quarts. Just wondering how you fill it after you drain it?
You can drain n fill it, but you need a special tool to get the liquid in there. Under the tranny there is a bolt that can be loosened to remove the oil. But you have to fill it from the the top and there is no room to even stick a hand in there. Honestly tranny fluid doesnt require service, i feel you will do more harm then good.
How many miles on the car?
