question about signal warning cancelers
ok so i replaced both the rear and front turn signals with LED bulbs and they blink too fast and the signal light on the inside blinks super fast as if the bulbs are burnt out.
the guy at the shop said he could install the warning cancelers in the rear no problem however he said for the front turn signals its all plastic and the cancelers get way too hot and will melt everything.
are there any alternative cancelers that don't get as hot, or is there some other way of solving this problem so i can keep the led bulbs and not have them blink way too fast and send the error message?
any help greatly appreciated.
cheers.
cheers.
cheers.
cheers.
I got mine LED signal kit from Think Design Japan for $260 when V-LED's flasher out of stock...
That's exactly what I did and it works flawlessly. This is what you need.
use coupon code "NOTIE15"
that will save you 15%,
GOOD LUCK!!
super400
SC- 1st Gen (1992-2000)
08-03-16 08:34 PM
cr00klyn71
General Classifieds
05-20-10 10:28 PM
