2006 GS will not start
[B]Car shut off while driving one day but didnt give any codes. Crank it back up and drove it the next two days. Then it would not start at all the next day after I drove it to work. It tries to crank but acts like it's not getting fuel. Used engine start spray and it would start up but shut down once you stop the spray. Not sure if its the fuel pump, fuel filter, EFI, or a fuse. Has anyone seen this issue and/or know how to fix it?
Need location of Fuel pump, fuel filter, EFI or the fuse if one of those is the issue. 2006 GS300
Thanks,
KD
Thanks,
KD
Yes, checked battery. Also car started and ran as long as engine start was being sprayed into the intake, so its an issue with the car not getting fuel.
Update: Car started up this morning but ran a little rough. So i'm thinking it may be the fuel filter. Any help or suggestions??????????
