How much did you paid for timing belt replacement??
Old 07-05-12 | 04:30 PM
modonna223's Avatar
modonna223
Default How much did you paid for timing belt replacement??
My car just hit 90000M today so now i 'm going to replace the belt for my GS.but$$$$
Old 07-05-12 | 05:27 PM
Brabusx2's Avatar
Brabusx2
it runs on chain, they last longer so u don't have to worry 90k miles isn't that high
Old 07-05-12 | 06:38 PM
Boron's Avatar
Boron
Not unless the OP is running the 430, it's still a rubber band.
If it's the 300/350/450h/460, then chain shouldn't need replaced at all.
Old 07-05-12 | 08:54 PM
tucker21's Avatar
tucker21
I'm confused by this post. I have a 2006 gs430 approaching 90k miles.....what should I expect at the 90k service?
Old 07-05-12 | 09:00 PM
twylie's Avatar
twylie
timing belt and water pump as a safety precaution + standard tune up items. 90k is the big ticket service for 1UZ/3UZ engines.
Old 07-05-12 | 09:35 PM
worker's Avatar
worker
^ and while at it check other fluid too. 100k miles is like a full complete check up time.
GS430 uses timing belt. Did mine at 100k too. water pump/coolant flush/ axle fluid too/ and I think did the gear fluid too... I forgot.
Old 07-05-12 | 10:29 PM
masboy's Avatar
masboy
CL Folding 25,000
timing belt + water pump labor is $300 in my local shop.
buy the parts from sewell, that's what i did.
Old 07-06-12 | 02:39 PM
alchemist's Avatar
alchemist
that's a good price in my opinion. I'd do drive belts same time as well and inspect pulleys and gaskets.
Old 07-06-12 | 03:04 PM
Boron's Avatar
Boron
How so?
The 430, a carry over from the 2G GS, is a V-8 with "rubber band" (timing belt).
The 300, with it's newly designed V-6 (2G GS was inline-6), and the 350/450h V-6, and the 460's new V-8, were all switched to timing chain, as has been the industry norm for nigh on a decade.
Therefore, your biggest cost/concern is going to be the belt being replaced as per schedule recommendation.
Interesting to see mention of the water pump, which is listed on Sewell's site (and I wondered why that should be the case), is reminiscent of BMW E65 7 series as a bit of an issue/concern.
Old 07-06-12 | 03:23 PM
Ap1_Alan's Avatar
Ap1_Alan
It's common practice to replace the water pump along with the timing belt. Since you'll have to remove the timing belt to change the water pump, it makes sense to do them together.
Old 01-24-13 | 04:17 PM
PeteV's Avatar
PeteV
Can you share with me what shop?
Old 01-25-13 | 12:00 AM
masboy's Avatar
masboy
CL Folding 25,000
i can share it with you but not sure they will give you same price, that's the thing.
PM if u still want to know.
Old 01-25-13 | 05:16 PM
anthrax144's Avatar
anthrax144
The timing belt and serpentine belt are not the same thing. The serpentine belt typically gets replaced with the water pump. The timing belt is under a cover behind all those accessories and is quite a bit more complicated to replace.
Found this vid if you want to take a look:
Old 01-25-13 | 08:26 PM
ibidu1's Avatar
ibidu1
A timing belt is not really something you want to do a diy on because you can really screw up the engine by putting on the wrong tooth on one of the pulleys. 200-450 is about what shops charge to replace timing belts and water pump
aj007
08-04-15 09:24 PM
lyonkster
01-02-15 09:25 PM
dadoody
06-23-14 09:05 AM
pakattack
02-18-13 11:08 AM
dumdumgreg
06-16-06 03:55 PM
