LED lights on Lexus gs 350
What are your thoughts on puttin LED lights on a 2010 lexus gs 350?
Take out the fog lights and place the LEDs...?
Would like opinions or any feedbacks!
Thanks
Thanks
i was thinking bulbs, but, if you mean that... someone's already done it.
It's under tucker21's thread pertaining to LEDs....
https://www.clublexus.com/forums/gs-...ed-strips.html
That picture you posted is exactly what i want to do! Looks beautiful.
Also i had a question i think you might know.
Is it possible to turn the cars lights on when you open the door?
Like when you reach to open the door as in when the door unlocks the headlights turn on?
Anything is possible, but it's more a question of why you'd want such a feature.
Bit pointless really, as you're getting into the car, and will be starting it up.
If not, then the extra draw on the battery will reduce the power available to start the engine.
You could rig the DRL LEDs you're thinking of installing to switch on with the courtesy lights, but then they'd be off when the lights go off as you start the engine, and would only be on at a dimmed level once you turn the headlights on.
I'm sure you could get round that, but it's all starting to get complicated and messy.
