Small Dent from Curb :( What to Do?
I accidentally parked too close to the curb and when i backed out, i guess something on the curb bent a piece of my bumper outwards.
Any advice on what to do? I tried a hairdryer for 20 seconds but it only bent back in a little? Maybe I was too quick with the dryer but Im just really pissed. Is this something I need a heavy duty heat gun on or could it be fixed with some patience and a hairdryer?
Im afraid though that if i heat the other areas, then when i push it in, the heated area will also cave in making it look dented inwards.
Any tips on heating it? how long i should heat it for? etc etc?
That's not bad at all.
On that one, I would just heat it lightly (hair dryer s/b sufficient) then take two pieces of wood, 1"x2" approx 6" long each and clamp them on either side sandwiching the bubble to flatten it out (probably will have to remove under-body panel) and leave it sit overnight. Might have to repeat for a few nights but should be fine then.
Good luck
Good luck
