need help caliper bolts is strip..
i have a 07 gs430 front caliper bolt strip..and the caliper nut strip..what can i do..? the bolt a 12mm 1.25 .. the tread is strip bad.. can i replace that part..? the nut on the caliper im asking....
So what you're saying is that where the bolt screws into the caliper is stripped? That is not a nut, it is part of the caliper. If it is stripped, and a tap or thread chaser can't fix it... you probably need a new caliper
Reviving an old thread here...
Somehow did this to the bottom bolt on my passenger caliper, Endlesslex any word as to whether you were able to rethread the caliper, or did you need to buy a new one?
SGLexus
07-17-23 11:39 PM
