20.8.5, +35 offset - What Size Spacer?
I suck at mathematical calculations so I am trying to figure out what size spacers I need to push my wheels to make the flush with my fenders.
Tires are 245/35/20 Nitto NT555's.
(I do plan on rolling/shaving my fenders if required)
Thanks in advance.
Thanks in advance.
I wouldnt run a spacer up front, I would actually leave it as it sits but you can push the rear more.
if you do shave the rear fenders then I would go with a 20mm if you want it flush it will be right on spot. You will also need to shave the rear bumper tabs down. I would go with a bolt on spacer so it will go one and come off easier if you dont like them or swap out your rims with a different offset.
ohiois350
02-01-12 11:15 AM
