Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
- Lexus: Why is My Car Misfiring?
Guide to diagnose trouble and recommended solutions
FINALLY....Recall on GS300 engine misfire
#301
Interesting... I haven't experienced a knock at start up (yet) **knock on wood** lol
As for your info about the chain/belt, you're half right.. I got the drive belt replaced, you are referring to us having a TIMING CHAIN and not a TIMING BELT. The drive belt runs only accessory components like A/C, water pump, alternator, etc.. Timing belt/chain run the crank and camshafts. Correct me if I'm wrong anyone..
I had this done to my car. Mobil 1 makes my car knock At start up. Was told that our cars don't need to get the drive belt changed as they have a drive chain. And the onlt time you replace it is when it snaps.( breaks) All I replaced was the spark plugs and water pump. Free labor on all the parts I had to buy that where not included in the recall. Have 175.000 + miles 2006 GS300![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
#302
your right , my bad. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
#303
I am not buring more then 1 quart per 1000 miles and only getting 18-19 mpg combined on highway and street and 23-24 on highway. I want to take it to sewell lexus do I need to wait for the light to come on, on the car? I think I have black exaust tips but I don't think I will ever get the car to show up a check engine light.
#304
Do they just automatically go to this fix if you have a check engine light due to random misfire codes, does everybody have to have the check engine light to get the fix or go through a lengthy process of verifying oil consumption?
I have (as always) erratic idle especially when first starting up, bounces up and down... car sometimes vibrates when I'm at a stop. Exhaust tips always full of black soot. Lexus previously did top engine clean and it has run better since but the symptoms are still there. I had the check engine light come up for misfires a few weeks ago again, but I stupidly cleared it figuring they wouldn't do anything about it anyway but now I know I should have at least brought it in and seen what they had to say even if it might mean just flushing a diagnostic fee down the toilet. Well... if it came on once it will come on again I guess. I just wonder if they will tell me I have to do unnecessary stuff instead like change my spark plugs (they have only like 15,000 km on the plugs) etc. etc.
#305
I just dropped my 06gs to lexus today. They will be replacing the piston rings, water pump,drive belt, and spark plugs for less than 400 combined. My car was doing exactly what yours is, minus the codes. I only went there and told them about the oil and idle problems and they ran a 30 minute diagnostic test and said it was the piston rings. The other stuff was recommended since I would be saving on labor. I had no codes, but they gave me zero hassle. Only stated that this has been happening with the 06 gs and lexus would take care of me. They said it would be 2 weeks or more until they are done, they gave me a 2013 rx350 to drive around until then. I would just ask them to take a peek at it if I was you.
-P0172 System too rich (Bank 1)
-P0301 Cylinder 1 Misfire
But the dealership said corporate rejected the claim since they couldn't determine carbon build-up was the direct reason. BS. This was at Longo Lexus in El Monte, CA. Where did you go? I should just go there.
This is on a 2006 GS300 w/103k miles.
#306
My car did not show a check engine light but it did show the symptoms, black exhaust tips, rough idle, etc.. They ran their tests and the codes showed a misfire and Lexus approved the service.
#307
That's awesome. No error codes and they still did it for you? I took it in, complained of oil consumption (about 1.5 quarts over 4000 miles) and my car threw the following codes that the techs saw in memory:
#308
Mine is at Longo Lexus now, dropped it off Sat and my CEL disappeared while driving there. BUT, they're going to check it out and call me when they figure it out. OH, my service agent said the misfire was done at 73k miles and I have 83k on it now. I still have the same symptoms. Luckily, they said Cerritos offers a 1 yr warranty. Will fill you guys in when I get it back or hear back from them.
#309
What check engine codes are you all getting if I may ask? I had a check engine light go on and it just said check vsc. I cleared it by unhooking the battery and it hasn't come back on.
I have complained to Lexus several times about low oil levels and they keep telling me that it is normal to burn 1 quart every thousand miles. To me this doesn't make sense since the car takes about 5 quarts and there's an oil change every 5000. I took the car in the last oil change an there was no oil on the dipstick. The low oil light never came on so I didn't think much of it.
#311
It's actually a customer support program. So it's not really a "recall" from what I've read on here. I don't remember my code since my CEL came on 3 diff times in the span of 3-4 months. Lexus just called, claims my car is perfectly fine, doesn't experience any loss of power, drive is fine, and they tried to duplicate the grinding sound I tend to here when i start my car. I only hear the sound every now and then. So I know that isn't normal. OH, to top it off, my piston rings were done at 73k according to the VIN. BUT, lexus was nice enough to not charge me for all of this and said it's all free of charge and no need to pay the $135. NOW, i just need to figure out the weird "grinding" sound I hear when I start my car.
#312
Lexus sent out a letter about a year ago, maybe more. Just take it to the dealer, and if youve had check engine light, and had low oil go ahead accept the diagnostic fee. Once they scan the computer and find error codes thats when I believe they will cancel that fee and perform the repair for free.
#313
Ok imma take it up to lexus this week. I called dealer and corporate and they acted like i was crazy or something. But i dont have a check engine light on? Or does that matter? I just changed my oil two weeks ago and my low engine oil level light popped on
#315
