Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
- Lexus: Why is My Car Misfiring?
Guide to diagnose trouble and recommended solutions
FINALLY....Recall on GS300 engine misfire
#391
Krava thank you for your response. I registered my car with lexus owner and found it's been maintenanced (and originally purchased) at lexus of Easton in columbus ohio. I contacted them an asked if I could have an oil consumption test done. They said they'd be happy to do it but it's gonna cost $119+tax. I was told they will change the oil and top it off and seal the motor up so no oil can be drained an I'd return the vehicle for inspection after putting 1200 miles on it. Is this what you or anyone else had to do? I don't mind the $119+tax, I just want a reliable vehicle
#393
I seem to have solved that issue in my car by putting a glob of RTV gasket goop at the end of the rear O2 sensors where the wires enter the sensor. I was grasping at straws when I did it but I haven't had the code since that was maybe 6 months ago?
#394
Thank you so much!!! I've only owned the car 3 weeks an every hard rain it appears (twice so far). This has been driving me insane. Getting in a lexus looking at that light made me not even want to drive the car. I'm going tomorrow to my friends shop to put on the lift and try your method.
#395
#396
You don't need a lift, you can easily get to them just by laying on the ground under the driver and front passenger doors. You don't even need to jack it up. It was only giving me the code for one side repeatedly but I just gooped up both sides with the cheapest engine gasket RTV on the shelf.
#397
I was going to do the oil consumption test but sewell lexus decided to put the car on the computer to read any misfires and after that they had a lot of misfires and I ended up not doing the oil consumption test and they told me to leave it and come back and they will fix it and no longer needed to do the oil consumption test since they saw these misfires. The car has to misfire enough to put the check engine light on but there is a boundary somewhere between no misfires and the check engine light that they will fix this problem
#399
[QUOTE=krava;8643479]you should have told them, if you car fails the oil consumption test will they do this procedure. if they said yes go ahead and prove to them this has a problem[/QUOTE
I haven't scheduled it yet so I'll ask them before I schedule it. If they say no I'll try another one we have 2 more with in an hour from my home
#400
From looking at the internal documents for this service on alldata, I got the distinct impression that although the fix for oil consumption and misfires are the same if you have issues with oil consumption without misfires it is NOT covered.
Anyhow I finally found a dealership at least willing to humor me and look at the car to do some "tests" for a nominal fee to see if they can cover this repair for me. I fear that since I had the top engine clean done not too much mileage ago that they will end up not finding what they need to see. Anybody have any tips to try to ensure the likelihood that the car will be misbehaving on that day would be appreciated. Ever since they did the top engine clean, the issue has been much more infrequent and subtle compared to the outright feeling that it was going to stall out on me at stop lights prior.
#401
#402
just dopped off my car monday and they said its approved for the piston rings and valve springs, i orinally wanted oil consumption test but didnt feel any misfires. they told me without the misfires they wont cover it just for oil consumption. so they did the misfire test instead and got approved. should be ready thursday ill you guys know how it goes.
I really want this done, not because of any particularly bad driving concerns (at the moment) but more for peace of mind continuing to own this car going forward - I am in no rush to replace it at all.
#404
