Heating and Blower Issues
Currently having problem with both heat and how the car is blowing air through the vents.
The climate control interface allows all directional blowers to be selected (individually), however! - No matter which selection is chosen air only blows through the main vents. Air will not blow by the feet or through the defroster vent.
Also, AC works great but heat does not work effectively. On the highest setting we are only getting warm air in the 70's(F).
Have looked online at the manual but haven't found anything of use. Any direction would be appreciated.
Additional info: 2006 GS 300, 112k miles, 2wd, no navigation. Recently purchased used.
The driver window controls had to be reset so they would work when we first purchased the car. So maybe there is something electrical that needs to be reset?
Thanks ahead of time for any help.
I saw your post but I never heard of a problem like yours. I didn't want to suggest you an obvious suggestion.......dealer.
My guess is the motors or Servos opening and closing the ducts is malfunction.
