Race Fuel Any Benefits!
^ did yours shivered like my gs430? it never shiver when using regular gas. but it does it from the first time start up with 91 gas till the second tank almost ran emptied. i fill the 3rd tank back to regular gas and it drove normal again. this is how my gs react to 91, so i wonder if others had the same reaction.
When you say regular gas, do you mean 93? Because if your car shivers on 91 then understandable, it is knocking and running rough. But the other way around.. doesn't make sense.
If DFI, you may end up clogging your injectors with fuel that contain sulfur.
Our cars are meant to run on 95RON fuel ( which is equal to 93MON in the US ). Unless your vehicle is programmed to advance ignition timing, anything above these ratings won't help you in any department.
Ya, that is another issue with race fuel some clog up your fuel injectors. But, sunoco is good about that. I used to race motorcycles and we would run VP race fuel and after every race we had to empty out the gas tank to remove the race fuel. One day I forgot to empty the tank and the screens in all my injectors were gummed up.
1995LS400
20
04-09-08 08:54 PM
