GS300 Claybared, Sealed and Waxed
Sorry, crappy iphone pics.
Claybared, Sealed and Waxed but i'm still seeing water spots everywhere.
GS300 (Flint Mica)
ML + isimple mod
Plastidip rear emblems (flat black)
Vossen CV4 Matte Graphite Machined (enroute)
Lowering mod possible (RCA blocks or springs)
GS300 (Flint Mica)
ML + isimple mod
Waterspots are just a function of mineral deposits in your water (known as hard water) and can easily be eradicated by final rinsing with deionised water via a resin vessel (sheeting with a low flow rate after rinsing the shampoo first) or using this.
If the deposits have etched into the paintwork, you'll need to use a polisher, but if you're not au fait with how to wield one properly, then a dual action is your safest option.
Lexus, like most Japanese paints is fairly soft, so you won't need a heavy abrasive nor firm pads - a medium pad with light cut and the same or refining polish on a soft should do the trick.
Try the soft and refining first, before stepping up to the light cut, and if a pass or two isn't having the desired effect, swap to the medium pad.
Thanks Vossen! I'm a fan. My third set of Vossens. Thanks for your wonderful wheel and customer service. I would vouch for your brand any day.
http://www.autogeek.net/detailing-clay-bar.html
http://www.detailedimage.com/Ask-a-P...se-a-clay-bar/
http://www.bilthamber.com/clay-bars/auto-clay-regular
Should enlighten you to the world of claying your paintwork.
