06 Lexus AWD Tune up. HELP!
Old 01-06-13, 01:15 PM
LexusFan09
LexusFan09's Avatar
Default 06 Lexus AWD Tune up. HELP!
Hello all,
I just did the tune up on my 2006 Lexus GS 300 AWD. Well First of all I changed all 6 spark plugs. I did not put any oil on the spark plugs before putting the new ones in. Was that a bad idea? Also I had unplugged the battery and im guessing everything has to reset itself? I took the car for a test drive and it seems like the car was idling kind of hard and also it was jerking at first. Anyone have any feedback on this. Much appreciated. Thanks
Old 01-06-13, 02:17 PM
ibidu1
ibidu1's Avatar
You should never put oil on your spark plugs, you can put anti seize on the threads but not really necessary.
Rough idle at start up when you first disconnect the battery is normal.
Old 01-06-13, 03:15 PM
LexusFan09
LexusFan09's Avatar
Will it take a couple of drives for the rough idle to go away? Also when it accelerates it kinda seems likes its pushing.
Old 01-06-13, 03:16 PM
LexusFan09
LexusFan09's Avatar
I don't know just after I did the tune up today the car seems like something is wrong with it. My step dad said it takes awhile for the car to get used to the new spark plugs. I'm not sure if that's right or not.
Old 01-06-13, 03:34 PM
ibidu1
ibidu1's Avatar
Are you sure you seated all the plugs properly? Also did you use oem plugs? If you used another brand, that could give you issues.
Old 01-06-13, 05:04 PM
LexusFan09
LexusFan09's Avatar
I used some spark plugs from advance autos.
Old 01-06-13, 05:16 PM
ibidu1
ibidu1's Avatar
What brand and model plug?
Old 01-06-13, 05:56 PM
LexusFan09
LexusFan09's Avatar
http://shop.advanceautoparts.com/web...923%7CL2*15034
Old 01-06-13, 07:13 PM
ibidu1
ibidu1's Avatar
Ya, I think that maybe your problem right there. I would take those out and run the factory plugs, I believe they are denso. Advanced auto should carry them, they didnt offer it to you?
Many cars are sensitive to spark plugs
Old 01-07-13, 04:39 AM
LexusFan09
LexusFan09's Avatar
No they offered those plugs they said they were the right type of plugs to use.
Old 01-07-13, 04:40 AM
LexusFan09
LexusFan09's Avatar
So what type of spark plugs should I use
Old 01-07-13, 06:12 AM
Simmsled
Simmsled's Avatar
OEM Denso plugs, Lexus part # 90919-01249
Fits all of these:
GS300: 2006 - 2006
LS460: 2007 - 2012
LS600h: 2008 - 2012
GS350: 2007 - 2013
GS450h: 2007 - 2013
GS460: 2008 - 2011
and also the IS350 but not sure if it is all years.
Sources:
http://lexus.sewellparts.com/accesso...2006/3377.html
https://www.clublexus.com/forums/is-...g-service.html
Old 01-07-13, 07:25 AM
ibidu1
ibidu1's Avatar
I believe sewell lexus with the CL discount they are 10 bucks ea
Old 01-07-13, 07:14 PM
LexusFan09
LexusFan09's Avatar
Thanks I will look into getting those spark plugs. Do they sell them at auto zone or advance? That's where I get most of my parts
Old 01-07-13, 07:28 PM
ibidu1
ibidu1's Avatar
Ya I am sure they have it or they can get it, but most likely they will probably be priced like the dealer which is probably around $20 bucks a plug.
But I would tell them your case that they suggested a certain plug for you and your car is running like crap see if they can help you out any. Won't hurt to try!
You'll want the Denso FK40HBR11 Iridium. Goodluck and let us know what they say
Quick Reply: 06 Lexus AWD Tune up. HELP!
