GS350 Water Pumps
Old 01-14-13, 05:41 PM
ibidu1
ibidu1's Avatar
Originally Posted by burny
Thanks bro, can you post a link of those idler gates so I will know what you are talking about. maybe you are saying it is a Gates idler roller?
It's an idler pulley, company is called Gates. Heres a link
http://www.ebay.com/itm/400331919901...84.m1497.l2649
Old 01-16-13, 10:06 PM
fventura03
fventura03's Avatar
great info
Old 01-17-13, 09:31 PM
passnu2
passnu2's Avatar
only issue with eBay is getting the seller to honor the warranty. Our vendor, Sewell Lexus, ClubLexus Price:$155.82 for the water pump. At least your backed up should it be a bad part of have premature failure. The other parts I wouldn't worry as much about.
Old 02-02-13, 11:09 PM
mqnyc
mqnyc's Avatar
Default Which water pump parts do I need to order from Sewell?
Sorry for the dumb question. I want to buy the pump parts and have my local mechanic replace but have no idea what parts to order from Sewell I need from the list below.
Can someone help?
$154.55 : PUMP ASSEMBLY, ENGINE WATER [16100] x 1
$61.62 : PULLEY, WATER PUMP [16173] x 1
$2.38 : BOLT FOR WATER PUMP COVER [16193A] x 2
$20.53 : GASKET, WATER PUMP [16271] x 1
$44.44 : PULLEY SUB-ASSEMBLY, IDLER, NO.2 [16604] x 1
$205.14 : TENSIONER ASSEMBLY, V-RIBBED BELT RWD - REAR WHEEL DRIVE [16620] x 1
$205.14 : TENSIONER ASSEMBLY, V-RIBBED BELT AWD - ALL WHEEL DRIVE [16620] x 1
$1.88 : PLATE, IDLER PULLEY COVER, NO.2 [16659] x 1
$2.23 : GROMMET [99999] x 99
$0.55 : BOLT, FLANGE [99999] x 99
$1.07 : BOLT, FLANGE [99999] x 99
$1.24 : BOLT, FLANGE [99999] x 99
$0.72 : BOLT, FLANGE W/WASHE [99999] x 99
$0.59 : BOLT, W/WASHER [99999] x 99
Thanks
Old 02-02-13, 11:47 PM
ibidu1
ibidu1's Avatar
This is the pump and idler pulley
Old 02-03-13, 12:14 AM
mqnyc
mqnyc's Avatar
Thanks ibidu1 and for bringing the water pump to my attention from the other thread.
So the existing larger pulley and gaskets could be reused?
Thanks again.
Old 02-03-13, 11:20 AM
ibidu1
ibidu1's Avatar
Thanks again.
I'm glad it made people more aware of the situation.
You can reuse the pulley, and the water pump gasket comes the water pump kit #16100
If you wanted to go all out you can replace the tensioner, but those are $200 bucks
Old 02-04-13, 08:17 PM
mqnyc
mqnyc's Avatar
Thanks! Just ordered the kit + pulley sub-assembly for $200 + 3 gallons SLL coolant.
Old 02-05-13, 07:40 AM
Gennady7
Gennady7's Avatar
Thank you ibidu1! I just ordered the pump and the belt on ebay for my GS300. I have to change my thermostat and felt that it was a good way to get this done as well. I did not order the pully, is it recommended that I purchase it?
Old 02-05-13, 07:49 AM
ibidu1
ibidu1's Avatar
You can reuse the pulley, just clean it
Also just make sure to use blue loctite on all the bolts.
Old 02-05-13, 09:03 AM
Gennady7
Gennady7's Avatar
What is blue loctite and how do you apply it? By the way, thanks for the help.
Old 02-05-13, 10:03 AM
ibidu1
ibidu1's Avatar
Loctite is a thread locker, it helps prevent bolts from backing out from vibrations. You have three strengths. Since there's lots of vibrations in the water pump and engine block its best to use thread locker. A tiny drop on each bolt is enough. You can get them from any auto parts store
Blue- Strong, but easy to disassemble / work with
Red- More of a permanent application
Green- good for heat applications, stronger than red.
Old 02-05-13, 12:12 PM
Gennady7
Gennady7's Avatar
Thank you very much I will give everyone a heads up of how it went on the 300!
Old 02-05-13, 12:35 PM
ibidu1
ibidu1's Avatar
Great, goodluck! Are you doing the job yourself?
Old 02-12-13, 02:35 PM
msgs350
msgs350's Avatar
Great info here
Quick Reply: GS350 Water Pumps
