Front Camber kit
Front Camber kit
I am looking for front adjustable A arm camber kit. I know top speed A arm for IS300 fit 3GS but top speed no longer make them anymore. SPC ball joint will only give -1.5. If you know manufacture or any way such as modifiing other car model front camber kit (G35) please let me know!
****i need front camber kit to make more camber****
I got the SPC ball joint which helped get me close but I could not find any company which made an adjustable control arm. One company (FIGS Engineering, their answer to my request is below) said they were going to but then sent me an email saying they couldn't make it work because not enough room.
FIGS Engineering "Well one issue we ran into is that there is no room for camber correction via the upper control arm, there simply is not enough fender spaces to push the ball joint out anymore. If you are interested in the closest solution for camber correction then it will be the SPC balljoint, which we also carry. However the SPC balljoint has some drawbacks, namely the upward clearance."
07IS350
Suspension and Brakes
03-30-11 04:59 PM
