Headlight discoloured
Old 01-27-13, 05:41 AM
Dean8788
Dean8788's Avatar
Default Headlight discoloured
One of my headlights has got a bit tatty looking slightly yellow tinge sort of tarnish to it, which just washing does not remove. I have heard that sand paper can clean it up to look like new again how true is this?
Old 01-27-13, 05:50 AM
alchemist
alchemist's Avatar
Look up 'headlight restoration'. There are kits out there for this.
Old 01-27-13, 05:54 AM
Dean8788
Dean8788's Avatar
Thanks Alchemist will do
Old 01-27-13, 07:34 AM
ibidu1
ibidu1's Avatar
Do not sand your headlights! There is a thin coat of clearcoat that you need to help keep on there. If you sand your headlight with one of these kits (like the 3m restore etc) you will end up with a bare plastic headlight. Sure it will polish up temporary, but it will get way worse then what it was after a few months because no clear coat.
Best way that I know if the your clear coat is still good is to use mild cutting compounds. There are products out there that can cut it. I like to use professional stuff a product by meguairs m105 then m205.
If your headlights were really bad you can use a fine sand paper like 2500-3000 grit and lightly sand then use compounds to polish it up.
If your clear coat is to badly destroyed, you can take your headlights to a body shop and they can sand and spray clear coat on them.
Old 01-27-13, 07:47 AM
BinaryJay
BinaryJay's Avatar
Yeah sand the headlights, they're going to look like those headlights you see on other cars once in a while and wonder how the hell that even happened.
Old 01-27-13, 08:15 AM
ibidu1
ibidu1's Avatar
^^^ Yes after time (3-4 months) your headlights will look like that if you use one of these sanding headlight restoration kits.
Notice the clear is almost completely stripped off. The only thing that made the headlight shine before was the compounds that had fillers. What they do is they fill in the scratches and after time the wax/compound breaks down and exposes the scratches.
That headlight could still be repaired, needs more sanding and spray a clear coat.
Old 01-27-13, 09:59 AM
3GS404
3GS404's Avatar
I'd sand couple times but after time its still will become yellow again bro ! Just spend $50 to spray a clear coat on ur headlight then u done for good ! U dont have to worry about it will get yellow foggy again !
axis77
04-11-16 10:24 PM
D3V3LOP3R
01-31-15 08:35 PM
tonycard
Automotive Care & Detailing
18
08-19-12 01:14 AM
94LEXUS400
SC- 1st Gen (1992-2000)
03-26-11 04:23 PM
92Es300 5sPd
Lighting
26
10-27-02 11:15 PM
Quick Reply: Headlight discoloured
