06 GS300 MPG issue *** need your input
Old 02-14-13, 11:47 AM
m2kGS300
m2kGS300's Avatar
Default 06 GS300 MPG issue *** need your input
Dear All,
i have a 06 GS300 RWD, 95k miles, 18" rim, tire: 245/45/ FR / 255/45/ RR.
i also have a DC short ram intake, car is lowered slightly about an inch all around.
reguarily oil change and maintenece, and i drive mostly speed at 40 mph on the streets.
above is about all mods i've done, but i am getting 13MPG in city, that is really bad, and before the intake, it was about 16 MPG city.
i thought by changing the intake would give me a little better MPG, but seems like it did worse.
Does anyone know anything i can do?????
Old 02-14-13, 11:59 AM
IXI187IXI
IXI187IXI's Avatar
there is so much that contributes to MPG it would be hard to pin point. 13 does seem extremely low, even with a heavy foot you should still be at about 17-18mpg.
Old 02-14-13, 06:11 PM
Simmsled
Simmsled's Avatar
Depending on what kind of mechanical ability you have, I'd check the spark plugs.
If they have not been changed, that could be a factor. I've seen short rams that actually make cars run worse, might want to put the stock intake back to see if it was the source of your issue.
Make sure your tire pressure is adequate as well.
Old 02-15-13, 02:56 AM
fventura03
fventura03's Avatar
thats very low, I do half city/half highway driving and this I am getting 24-26mpg on average. do a tuneup, new sparkplugs/fluids and see if it gets better
gs300 rwd:
Old 02-15-13, 07:40 AM
TWong350
TWong350's Avatar
Wow...that's very low. I could have a lead foot on my 350 and still got above 20.
Along with the plugs, check that the air filter isn't clogged. Also check tire pressure. All three are big factors.
Old 02-19-13, 10:58 PM
BAR | F1
BAR | F1's Avatar
What kind of fuel are you using? Take a look at the pump next fill-up and see what % ethanol is being added. I have a 102k 06, I've always run 87 w/ 10% ethanol that the refinery bastards force on us. I average 18-20 mpg in mostly (spirited) city driving. Original plugs but peeping for major service in a couple of weeks.
Old 02-20-13, 08:01 AM
ibidu1
ibidu1's Avatar
I believe gas companies change the formula of their gas to cope with the winter season, and the gas does not last aslong as summer gas. I believe they call it winter blend
Old 02-20-13, 08:13 AM
Simmsled
Simmsled's Avatar
This is true.
Lvangundy
585
07-05-19 07:12 PM
silkx3
03-19-16 01:52 PM
Brokerjoke
Performance
18
07-16-12 05:53 PM
Sole350kid
Performance
04-06-11 06:31 PM
IS350atWOT
IS F (2008-2014)
08-26-10 12:58 AM
Quick Reply: 06 GS300 MPG issue *** need your input
