Am I going to rub?
1 Post
I have searched and read and read and read but I'm more confused as ever! I just ordered the tamale df210s for my gs460 and my cv3s and pirellis came in last week! Front offset is +38 and rear +45 my question is will my fronts rub running 245/35 20 on that 9 inch wheel? I'm confused after reading all these pages!
my 07 rubbed on the left front (+32), had to cut out part of the wheel well, AND grind the weld behind the well down some. only on left side though, and my car is stock height. 245/35
I am running nearly the same offset and tires on the front.... I am rubbing on left turn lock out. Im going to heat up that section of the well and push it in a bit. The problem is that the pirelli tire is very square from what im told. A different tire might do a bit better (falken?) Hope this helps.
is250rida
11-01-08 01:29 AM
