low coolant
Old 03-14-13, 04:10 PM
OGS350
OGS350's Avatar
Default low coolant
I have a 2007 GS 350, my coolant is at the low mark. should i be worried about this? have anyone had this this problem?
Old 03-14-13, 04:28 PM
Whitena
Whitena's Avatar
When engine is fully warmed up?
Old 03-14-13, 04:41 PM
OGS350
OGS350's Avatar
i didnt check when its warm but i will now. i was reading some ES forum were the water pump was leaking.
Old 03-14-13, 04:52 PM
OGS350
OGS350's Avatar
just check while the car was warm. coolant at the low level mark
Old 03-14-13, 05:58 PM
Whitena
Whitena's Avatar
If the coolant level still in low mark when engine is fully warmed then you should have it checked out.
Old 03-14-13, 06:07 PM
OGS350
OGS350's Avatar
ok. thanks
Old 03-15-13, 12:22 AM
ibidu1
ibidu1's Avatar
Don't risk it, you may have a bad water pump
Check this link out, GS350 pumps go out often, so if your car has mileage its best to replace it right away.
https://www.clublexus.com/forums/gs-...ter-pumps.html
Old 03-15-13, 12:33 AM
OGS350
OGS350's Avatar
ok. thanks. currently have 67500 miles. do anyone know if its covered on the pwertrain warranty?
Old 03-15-13, 06:21 AM
bigblack06
bigblack06's Avatar
yeah I would get it checked, you could have a bad water pump like ibidu1 said, I had the same issue but I caught it early, someone on the forum wasn't so fortunate. Yes it should be covered under your power train warranty.
Old 03-18-13, 01:39 PM
OGS350
OGS350's Avatar
had my car checked out by lexus today. they told me I had air pocket in coolant system which came from the last time it was there beening serviced for cam gears replacement
Posted from ClubLexus.com App for Android
Old 03-18-13, 01:41 PM
ibidu1
ibidu1's Avatar
Man, dont risk it just replace that pump
Old 03-18-13, 03:25 PM
chuckGS350
chuckGS350's Avatar
That's a big air pocket.
How long ago was your cam gears replacement?
Old 03-18-13, 04:53 PM
ibidu1
ibidu1's Avatar
I have a heard time believing the tech didn't bleed the radiator before letting it leave. Have the pump inspected
Old 03-18-13, 06:05 PM
OGS350
OGS350's Avatar
Old 03-18-13, 06:09 PM
OGS350
OGS350's Avatar
I wish they would have just replaced it(still under warranty) but they didnt because they found nothing wrong
Quick Reply: low coolant
