35watt ballast ---> 55watt ballast
Old 03-28-13, 06:24 PM
c-low
c-low's Avatar
Default 35watt ballast ---> 55watt ballast
has anyone ever swapped out the OEM 35watt ballast?? i really like the 55 watt ballast with 5k bulbs. stupid bright yes i know and living in WA its needed.
Old 03-29-13, 02:56 AM
IXI187IXI
IXI187IXI's Avatar
as long as the stock wiring harness can handle it, i dont see a problem.
Old 03-29-13, 06:44 AM
worker
worker's Avatar
^ heat is also a problem. 55watt been known to melt a few headlights.
Old 03-29-13, 07:36 AM
IXI187IXI
IXI187IXI's Avatar
i honestly dont think you need anything brighter than hids. are you using the proper temp bulb?
if your having problems seeing, use the high beams. if you think your lights arent bright enough, get into a car with halogen bulbs then drive yours again. you'll appreciate the difference.
Old 03-29-13, 08:15 AM
Gennady7
Gennady7's Avatar
I did the 55w with the fog lights as i was scared to melt the headlights. Went Yellow and love it, can literally see a huge difference (I didn't have hid's in the fogs before)
Old 03-29-13, 08:19 AM
1sWt2GS
1sWt2GS's Avatar
I'd be careful 35w is definitely bright enough running 55w can melt your housing!
Old 03-29-13, 11:13 PM
tunedis95
tunedis95's Avatar
I have 5k 55watt HID's for my high beams. Stupid bright. No like. Really helps on country roads
sagikun
05-21-16 05:53 PM
Basselc
Lighting
07-13-15 01:21 PM
2JZSteven
IS - 1st Gen (2001-2005)
04-26-11 06:58 PM
bigcory
11-25-08 10:41 PM
oat
Lighting
05-31-04 08:58 PM
Quick Reply: 35watt ballast ---> 55watt ballast
