Default help: 2006 gs300 warning lights galore
![](http://img.photobucket.com/albums/v203/yoteru/IMAG0695_zps682383ff.jpg)
Had some lights come on after lowering the car.
ABS light, check VSC on the display screen, traction light, and exclimation mark. The AFS light is also flashing.
Can anyone help with what these mean?
Thanks
Get the trouble codes scanned. Then we can help. Check that you didn't leave a speed sensor unplugged. It sounds like you might have damaged the AFS level sensor by lowering it and not adjusting it, or left it unplugged as well.
Everything is plugged in.
I checked the leveling sensor and that took care of the AFS light, but I still have the "ABS," "Check VSC," and "!" (exclimation mark)
Does anyone know what it could be?
Thanks in advance.
Thanks in advance.
executive matchup
i would recommend getting the codes scanned (as JSM1284 recommended) as it's difficult to determine what the problem is just by flashing lights.
edit: see this thread for possible solution: https://www.clublexus.com/forums/gs-...-vsc-help.html
did you check to make sure your gas cap is on tight enough? i recommend at least 2 clicks. see if that works for you.
I am waiting for the lexus mobile mechanic to come by and scan it for me...
I wish that was the case, but I have already had that service done. Thanks
BklynJay
09-16-06 03:35 PM
