Are wheel bearings covered under Powertrain Warranty?
Just wondering what peoples experiences have been with getting warranty repairs on wheel bearings. I have a 2007 GS350 AWD and I think one of my front bearings is starting to go. I hear a bit of howling so it will likely need to be replaced at some point.
Here is the exact language of the powertrain warranty:
Powertrain Warranty
The Powertrain Warranty is for 72 months or 70,000 miles, whichever occurs first. Except for the situations listed on the Basic Warranty page, this warranty covers repairs needed to fix defects in materials or workmanship of any component listed below: •Engine: Cylinder block and head and all internal parts, timing belt and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gaskets
•Transmission and Transaxle: Case and all internal parts, torque converter, clutch cover, mounts, engine control computer, seals and gaskets
•Front-Wheel-Drive System: Driveshaft, axle, hub, bearings, seals and gaskets
Powertrain Warranty
how can you tell if they are going out? i hear lot of noise but could be my tire, i heard there is a way by jacking up the car and play with your wheel up and down, left and right see if there is any play
The noise may not necessarily disappear when you turn. A bad bearing can make noise in a straight line as well. Tire noise changes dependent on road surface, a bad bearing will not.
sunamer (09-05-19)
Have to bring this thread from the dead to add info.
yes, bearings would be covered under PT warranty... UNTIL they are not.
Got a bad hub bearing on a rear passenger side. The noise started several days ago (IS350 2015 f sport) and I brought it to the dealership.
KC dealership (Hendrick Lexus, Merriam) diagnosed it and confirmed that it will not be covered under powertrain warranty because "there was some damage" to the bearing. A wheel on that side was not damaged, though. Got a quote of 1000+ dollars for repairs. Now, ordering the part myself and will be replacing it myself, once it arrives. I am not paying $1k for a shot hub bearing.
The damaged wheel was “already” on the other side, and apparently that did not help. My lexus adviser was insisting that the damage was due to something external (aka not a bearing defect). I see no reason for them to deny the coverage because they get paid by Lexus to perform a repair. I explained to her that I only have two options - they make a bit of money by fixing it under warranty = them getting paid by lexus, or not getting paid at all, if I were to fix it myself. She still was insisting that it was not covered.
I might try to go to another dealer, but at this stage, I already ordered the part...
The damaged wheel, is it bent or gouged up pretty bad? Next time they try to give the damaged wheel excuse tell them your wheel alignment is fine. So if a hard impact destroyed my wheel and for sure would have knocked the alignment off track.
If the 2nd dealer doesnt fix it, call lexus customers service, you paid for the warranty.
