Mirror issues
Old 05-02-13, 05:56 AM
Ironman50
Ironman50's Avatar
Default Mirror issues
Own a 2008 GS 350.
After reverse or when I fold in mirrors to park they don't want to go back to their 'memorized' positions.
So I have to manually reposition them.
Anyone had similar issues? Is this commom? Any recommendations?
Old 05-02-13, 06:05 AM
IXI187IXI
IXI187IXI's Avatar
either your gears are stripped or in the little drop down box, you dont have the left or right mirror selected. if neither are selected then the mirrors will not move.
Old 05-02-13, 10:35 AM
MizikeTSK
MizikeTSK's Avatar
I have the same issue as you when I put the car in reverse it points down but then does not go back up to the exact location and have to readjust using the switch. I think this was a common issue. I don't care to use the down tilt when in reverse so I left it as is. If under warranty/CPO see if your dealer will fix. I also think someone did a "how to" fix it but required you to open up the mirrors.
Old 05-13-13, 08:19 AM
zamri767
zamri767's Avatar
Default Same here..
Yeah, i have the same problem its getting rather annoying that it doesnt go back to the desired position. For me i really need to be in the correct position for safe over taking..And having to adjust it all the time is really troublesome. Thinking of disabling the auto mirror down on reverse. if only i had any idea on how
Old 05-13-13, 08:26 AM
IXI187IXI
IXI187IXI's Avatar
information has been provided for that...
Old 05-13-13, 10:33 AM
sprtdsgnGS
sprtdsgnGS's Avatar
Yep, gear problem. Had mine covered under the cpo warranty.
Old 05-20-13, 01:16 AM
zamri767
zamri767's Avatar
thanks IXI187IXI..will try it soon..
Old 05-20-13, 02:11 AM
duongn
duongn's Avatar
its an on going issue with most gs models. if your still under wrnty,the dealer will switch it out w/ a new mirrors as they did w/ mine...
Old 05-20-13, 06:49 PM
07LXgs350
07LXgs350's Avatar
does anyone know how much this would cost outside fo warranty
Old 05-20-13, 07:24 PM
TTKH
TTKH's Avatar
The problem that I have is every time in reverse, I would set it the way that I wanted down and out, but once I have it in gear like d or p and back to reverse it would go back to factory default.
MAFreeze
ES - 5th Gen (2007-2012)
21
03-24-16 07:13 PM
skipper469
02-21-11 06:37 PM
danlions99
04-30-09 02:26 PM
KiNg430
08-20-08 06:20 PM
minnister
07-15-08 08:14 PM
Quick Reply: Mirror issues
