Transmission Shudder/shake on light acceleration - Is this Normal?
I too have noticed this when slowly accelerating from about 20-30mph. However when going a little harder on the pedal it doesn't happen at all. Could this be cause for a bad axle/ cv joint, or maybe tranny mount? The shifting otherwise is smooth and responsive, and this only occurs when lightly pressing the gas. I figure it to be an AWD quirk as well, but have not really noticed this since first buying my car.
Its the torque converter in the tranny..... needs a new tranny my has same symptoms and it was diagnosed through Lexus of Maplewood in Minnesota. Highly reputable, the torque converter engages between 20 to 50mph thats when the shutter/shake happens
The transmission shifts fine otherwise with only this range of speed being affected if the throttle is applied slightly, but when added pressure is given it shifts fine. For a while I've been hearing a wobble noise and like a "whoom, whoom, whoom" noise when driving. The wobble I can probably cough up to a strut/cv axle, and the latter noise most likely a worn wheel bearing -- symptoms I know all too well from my last car lol. I changed the axles (2x), control arms, struts (3x) and only my driver's side wheel bearing. The symptoms before all those parts failed are what I'm experiencing now with my car when going over rough surfaces and the occasional uneven road surface. If a CV axle is faulty/blown, wouldn't it also affect how precise the shifts are when being transferred to the wheels, as well as the car feeling "planted"?
Side Note: when my mechanic had my car on a lift the transfer unit was audible upon rotation of either of my front wheels which also made the rear wheels spin. Car was not on and all he was doing was turning the front wheels to check for any components that would have an easy tell tale sign of wear. Is this bad? Not audible like "oh my god that's not music to my ears," but like a bat swung and the wind behind it kind of sound.
PS -- My gf's dad has an '08 IS250 AWD with 130K+ miles. The EXACT symptom up for discussion is felt on his car as well in the same EXACT mph range. The suspension on that car you can hear into the cabin when hitting certain road surfaces, yet the tranny shifts fine. It most likely never had fluids replaced aside from oil changes and the other fluids but doubtful on any tranny fluid -- unless their unit isn't a "sealed, lifetime" unit like ours and Lexus has some maintenance schedule for it different from ours.
It's such a PITA because the Lexus dealer near me refused to perform any transmission service with respect to a drain and fill since the unit is sealed, and has a lifetime 100K expectancy according to the service manager who I had take my car in. A statement I expected since a lot of people here mentioned it. Basically no shot at even getting it taken into consideration was the jist I got.
I would love for someone who works for Lexus as a tech, and has worked on these cars specifically to chime in and weigh on the build quality of these cars. I can wish right? lol
Issue solved. The transmission shudder (jerking/ hesitation) we have experiencing is due to a faulty operating torque converter, not because the converter is bad, but because the trans fluid is depleted.
GOOGLE how a lock-up torque converter works (the additives in the trans fluid is paramount here). How did I prove this? I took my car to the dealer to flush my transmission immediately after experiencing this issue to rule out the trans fluid but the shudder was still there, however, I did not realized that all the dealer did was to drain and fill (3.8 qrts). I then started down the path of looking for an used low mileage trans until I saw a post from another member about the success he achieved with a trans additive by Lubegaurd. I did a little homework on the additive he used and how transmissions work and figured I did not have much to lose by draining and filling my trans a few more times and give the additive a shot but after the second drain and fill (one by the dealer and one by myself), my shudder was gone completely for over 300 miles and I tried my best to make it shudder with no luck (bad luck for that matter). So for good measure, I went ahead and did a third drain and fill. I'm now going on 200 miles since the third drain/ fill with no issue. I did not include the additive but from my homework, it is a good product and will not hurt if decide to include for good measure.
My car had 130,xxx miles when I bought it and based on the maintenance history, the trans fluid was never changed.
Bottom line, we should be draining and filling our trans at least twice a year until we figure out a way to do a true flush.
AmanES300 (12-28-21)
Issue solved. The transmission shudder (jerking/ hesitation) we have experiencing is due to a faulty operating torque converter, not because the converter is bad, but because the trans fluid is depleted. Bottom line, we should be draining and filling our trans at least twice a year until we figure out a way to do a true flush.
