***Easy Fix For The Clogged AC Drain***
Well like many other owners I recently developed wet carpets in the back and damp carpets up front. After searching the forums I saw how common the problem was and TSB's that addressed the issue. Although I could drop the tranny and gain access to the plug as posted in the DIY by another member it seemed as if there was a better way. Well this is what I did and it took all of 20 mins start to finish with no unbolting of the exhaust, tranny or drive shaft.
After driving the car up on ramps I removed the black plastic cover from under the tranny held by 4 screws and 2 plastic nuts. Then used a lighted inspection camera with a flex head to see the plug. I purchased the camera from Harbor Freight Tools for 80 bucks. Next I used 11 inch long needle nose pliers with a right angle tip. With my left hand I snaked the flex tip camera up and over the tranny from the pass side just above the shift linkage. Then with my right hand I was able to get my arm up between the suspension and catalytic converter with the pliers. Keeping the camera focused on the plug I was able to guide my pliers to the plug and remove it.![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
I let the car run for 10 mins with the windows up and the AC on high to confirm that water was now coming from the drain. With my car long out of warranty this would have been an out of pocket expense. Just for safe measure I am going to pull the rear seat bottom and the front seats to remove the carpet. This allow me to clean the carpet thoroughly and spray lysol underneath to kill any possible mold spores as I am not sure how long the water had been there.
Hopefully this will help others. SInce its doesn't take very long to complete I would recommend others with 2006-2007 GS or IS cars do it as preventative maintenance. It can save alot of headaches and potential dangerous mold from forming in the carpets. With the factory mats covered with rubber underneath this can go undetected for quite a while.
Do you just leave the plug out once it is removed? What is the model # of that camera you have? Been looking to get one and this seems like a good reason. Thanks for your input
I'm guessing the grommet is just that - a seal for the drain tube. Thus whatever it may have been keeping out (water, exhaust, noise etc) however minimal, could now get in.. Is it something to worry about, maybe/probably not. I wouldn't say one way or another without seeing it myself.
Well done OP.
PS, were you able to perform this on floor ramps/jacks?
Cheers
Yes you do just leave the plug out once removed. Based on where its located I doubt seriously that anything will cause it to clog again. The TSB from Lexus advises techs to do the exact same thing by just removing the plug when this problem arises.
Dry passenger floors would be one.... ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Well done OP.
Cheers
Well done OP.
Cheers
I can vouch that leaving it off works. I live in Texas and its humid so my carpet was soaked. I was able to see the garment without a camera. It is at a weird angle but trust me you can see it if you look at the right angle. Also I tired poking at the drain and it did nothing so I just took it off
tthomas
Did you pull up your carpets afterwards to reduce mold and mildew? That is my plan for this weekend. I have not done it before but looking for any tips on getting the carpet out in one piece.
